1993 Festiva, manual, one of the 8 members of my Seattle fleet, with only 102K miles.
I've been smelling "exhaust smell" in the car for a while, and recently saw smoke coming out the front grille while at a stoplight.
I tracked it down visually to what appeared to be a leaky exhaust manifold to exhaust pipe gasket. This is the 3-bolt-hole gasket where the vertical section of the exhaust pipe attaches to the exhaust manifold. It's either that, or there's a crack in one of the parts through which exhaust gas was escaping. But it sure looked like it was coming out at the gasket, right next to the "tab" that sticks out (which I presume is so a mechanic can look at the joint and be certain that a gasket is in there).
I've removed the exhaust manifold from the car.
The subject gasket appears, strangely, to be 2 layers of material tack-welded to each other. Is this how it came from the factory, i.e. the best solution? The exhaust-manifold-to-block gaskets appears to be 2 layers also. I've ordered new of both gaskets from Napa. When installing, should I use any sort of paste-like exhaust sealant? If so, is there a brand name? The NAPA guy said no sealant is required.
BTW, I did a search before posting, and my Haynes books is 1500 miles away.
I'm surprised that a metal gasket like this leaked. I checked, and all three 14mm nuts were tight before I disassembled. Any thoughts? The car has only 102K on it. Any recommended torque setting for both this connection and also attaching manifold back to the block?
