Ok so I have to replace the lower sway bar bushings the ones that go through the lca is there anything that I need to know on how to do this is there anything special about doing this job?
Sway bar bushings
If they are really old then make sure you get all of the old bushing out of the control arm before installing new bushings or they won't want to fit in there right. It's also nice to have a friend hold the sway bar when your bolting it back together, but its not a necessity.
Tighten the nut till it stops. They have a shoulder to keep everything a set distance.-Greg
Redneck Engineer
FOTY - '09
Yes sir.Originally posted by muddevil01 View PostRight now there is a ton of play the old ones are shot. Will these bushings being gone cause there to be alot front to back movement in the wheel because that's whats happening-Greg
Redneck Engineer
FOTY - '09
i called around looking for these bushings today and was told that napa has no listing for them, and ford said they were NLA. the other place we usually use at work was closed so couldnt get them from those guys. where's a good source for these? im in need of the ones that go on the lower rad support too. saw the thread about modifying the generic energy susp. ones but not sure i want to go through all that if i dont have too.
does that make fms the only other real source?
( did notice rock auto has them but would really prefer to get them through the parts dept at work if at all possible)Originally posted by scirocco*joeProject Car Theorem:
If
a) w = all time
b) x = time spent at work
c) y = the number of project cars you have
d) z = amount of time you can spend each project car
Then
z = (w - x) / y
I got to go to the JY tomorrow and get some protege calipers. There is a festy there that is in great shape. If these bushings that you speak of are in good shape, do you want me to grap them up?89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
My site: 20tessa.sytes.net
Them are easy to get, he needs the 2 inner bushings that mount the sway bar to the core support. I dont even think the 2 inners are considered a bushing.Last edited by 91_festy_Gl; 09-02-2010, 10:53 PM.89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
I'm not sure what you are talking about...Originally posted by 91_festy_Gl View PostThem are easy to get, he needs the 2 inner bushings that mount the sway bar to the core support. I dont even think the 2 inners are considered a bushing.
Not "inners". MOOG k9737Originally posted by muddevil01 View PostOk so I have to replace the lower sway bar bushings the ones that go through the lca ...
"im in need of the ones that go on the lower rad support too"Originally posted by woodyvw16v View Posti called around looking for these bushings today and was told that napa has no listing for them, and ford said they were NLA. the other place we usually use at work was closed so couldnt get them from those guys. where's a good source for these? im in need of the ones that go on the lower rad support too.
Too, as in also. Not necessarily "inners".
For the ones that go on the LCAs look above for the part number. For the front (or "inner") swaybar mounts I used universal 1-1/8" (or 1-1/16" can't remember now) energy suspension poly mounts ground down to match the shape of the bracket and base. I had an Aspire front swaybar too (as in also
Oscar
"rubber isolators"
my searching has yielded only this diagram on fms's site that merely points and labels that for which i am searching as "rubber isolators"- the google/parts search that followed yielded no useful information. just alot of different versions of the moog number listed above (which i do need and was helpful- but i need the other ones too)
i may make an attempt to cast some in urethane... just like filling motor mounts but different.Originally posted by scirocco*joeProject Car Theorem:
If
a) w = all time
Then
z = (w - x) / y
Like I said above, you can use Energy Suspension universal polyurethane swaybar mounts/bushings/isolators.
You need to make sure to use the stock Festiva/Aspire body bracket. Grind down the ES bushing and it will fit well. I used a 4" grinder with a 40 grit sand paper wheel. It's been done several times before.
Oscar
