low beams wont work...
  • low beams wont work...
    Not sure why? everything else works brake lights,running lights, even high beams work.. any suggestion?
    LIVE FAST!!!!!!!DIE HARD!!!!!!!!:evil5::evil5::evil5::evil5:
    Dustin Hayek
    91.festy 1.8 BP DOHC AUTO.The turbo awaits!
    Worn out light switch?
      could be the bulb itself....its strange but both of my low beams blew at the same time for whatever reason....had to drive around with high's on
      Tyler
      91 Festiva, 5spd, B8 swapped, now for paint and suspension
        Hmm alright ill check both of those out. thanks guys
        Dustin Hayek
          If you go to the JY and find early 323s and 626s, from the 1980s, you will see that the switches are the same. You can even upgrade to a one-speed intermittent wiper from the 323, and variable-speed intermittent from the 626. Pull the steering wheel (21mm or 13/16 deep socket IIRC), then the complete switch cluster.
