A/C questions
  • A/C questions
    Does any one know if the aspire dryer will work on the festiva?
    Mine is probably good, but my dad said since it has been open for a week that it is full of moisture and won't do it's job good enough so told me to get a new one and well it is a discontinued item at work so i can't order one and wanted to know if the aspire is the same.
    Thanks guys
    Its not the the same the festivas used R12 freon and the aspires use R134a. Just put the ac system on a deep vacume for about an hour or 2 and it should be fine. The ac in my car was put together from a few cars in the junk yard that were all open and it still blows out 32 degree air with no problem.
      Ok that sounds like a plan.
      Thanks
        No problem man.
