shifter assembly
  • shifter assembly
    hi guys, i have a 1998 ford festiva, WF model i believe
    the problem I'm having is the manual shifter assembly sloppy as hell once again, I've already had to get 2 shifter assembly's since they seem to only last about 6 months before there so sloppy it just gets way to hard to drive
    and since now all the wreckers in my town don't have any manual shifter assembly's left i was wondering what other models of cars and years will the 5 speed shifter assembly fit in the festiva... I've hear rumors Mazda 323 shifter assembly's are the same but not 100% certain and dun wanna waste my time pulling it out only to find its the wrong one.. by the way I'm from australia so models of cars here may be different from overseas... also is there any way i can firm up a shifter?.. also id prefer something that's a direct swap as i don't have a hell of a lot of money and i'm not the engineering type so i cant make up plates and what not to fit other models shifters in. thanks
    Welcome to the best Festiva site on the internet. There are lots of info in the forum just use the search button at the top of the page. This link should get you started.
    Welcome again.
    Discuss making performance enhancements to the OEM-spec engine in your Festiva or Aspire.
    Jerry
    Team Lightning
    Owner of Team Lightning
    93 L Lightning. BP
      you just need new bushings probably....not a whole new assembly. Where are you located? Please add it to your profile when you get a chance....it really helps to answer questions and whatnot. Anyway....here they offer bushing packs at auto parts stores. They are used for door hinges and such. They are usually a mixed pack. There should be some that are real close and will help with the sloppiness. You also may be able to order new ones from the dealership....mazda, kia. Just need to find a car that coincides with your car.
        yea that's what I'm trying t find out which models is the same... tried ford for the bush kit... they told me no can do due to my car being to old... didn't seem very help full at all, called a different ford dealer basically the same story, it seems that they just don't wanna help you at all when your car gets to old..... although the Mazda dealer told me if i find the right model Mazda and the parts are the same they will do there best to help me get it
          also its only sloppy left to right up and down no problems at all
          also if anyone can could they possibly find a kit that's similar or the same on eBay for me so i know what i'm looking for
            Corksport
            Mazda and Mazdaspeed performance parts since 1998. Precision-engineered at an unbeatable value. 1-360-260-2675 - CorkSport Mazda Performance
              Originally posted by jimbowest View Post
              I took mine apart today. What is shown looks very much like the remains of what I have.
              A piece of stiff rubber hose with the inside greased with silicone grease would probably work. Put washers at the ends on the inside of the U to take up the slop.
              I looked at a piece of 7/16 that looked real close. Put the piece in boiling water for a few minutes and slather with silicone to stuff it in place and run the bolt through it.
              I'm taking my shifter to a builders supply store tomorrow to see what might turn up.
              I rolled up a piece of plastic cut from an antifreeze jug and stuffed it into the female part. I had to trim off a bit to get the inside diameter big enough to get the bolt through. That material is not that different from the $25 worth of bushings.
              My 1988 Festiva with 133 K miles was a bit sloppy.
              My recently acquired 1988 with 193 K mostly city miles had no bushings left. From what I'm finding, the car had been abused and not well cared for.
              If one got 5 years and 50 K miles out of rolled up plastic jug material, I'd call that good.
              Paul
              Red Rocket 1988 L, 133,XXX miles, 4 sp. AC, hit guard rail in snow, RIP, saved everything but body
              Black Rocket 1988 L 207,XXX miles, 4 sp. AC, engine, trans, wire harness, radiator from RR
              Red Rocket 2 1988 L 138,XXX miles, 4 sp
              White Rocket 1989 L 128,XXX miles, 4 sp. AC
                NAPA Shifter Bushings
                I found bushings today. A cooperative counter man looked and looked through the computer until a photo matched. He got two and they fit my shifter and bolt which I had brought along.
                The two with tax cost $2.78
                Photo of package with all numbers and bushings attached.
                Paul
                  ford escort and 626 have the same part number..
                  1989 Ford Mustang GT 5.slow
                  1996 Ford F-150
