Right I have something weird here.
I have a 95 WB Festiva also known as the Aspire as you know right
Here in Australia the WB's came with a 1.3l B3 yes?
Well my engine goes like a 1.5l but the head reads B301!
Isn't the B301 a 1.1l? I can't get a rocker gasket for it either, I had to modify a 1.3l B3 gasket. The lumps where the bolts go through are to wide and fat.
The basics is its a 8valve, the 1.5's here in Aus only came in 16valve.
The thing goes like hell and as of 6 months ago it started leaking oil into the cooland. Just a little, not enough to worry about because it goes out the overflow. I replaced the head gasket, the head "looked" fine.
But if it is indeed a 1.1l head on a 1.5l or even the 1.3l could that be the problem. Anyway I need some advice!
Thanx heaps!
Thanx heaps!
