Well my '93 started acting up today out of the blue it wouldn't start it would crank but not start so I checked for loose connections and all I get back in the car and it starts so I start driving it home and it quits just like someone shut the ignition off so again I open the hood and check things and it still doesn't start so after a bit of cranking I decide to push the car off of the road and wait for a ride well I get it coasting in gear with my foot on the clutch my foot slips and the car starts I drive it home and shut it off and it restarts and after about a dozen or so restarts I couldn't get it to duplicate the problem so I drive it to a friends house to see what he thought and when I get there and shut it off and it won't start we've tried everything we can think of and still no start any ideas? sorry for the long post
Random no start problem
module inside the disty."FLTG4LIFE" @FINALLEVEL , "PBH"
yes , yes, yes....expensive. It can be tested, it is expensive new. Ebay is your best bet for price if you want new. JY is best bet all together. Get the whole disty and just swap it out. Or if you know someone that has a disty see if they will let you use it to verify it is the problem.
Not exactly sure how to change it....never have. But if I had to I could."FLTG4LIFE" @FINALLEVEL , "PBH"
could also be the coil cutting out on you."FLTG4LIFE" @FINALLEVEL , "PBH"
Ebay has module's.....so does the JY!Dan
cool....you have one to pull from with known good parts. It will help a lot. good luckOriginally posted by muddevil01 View PostTomorrow I'm gonna try the coil and disty out of my '91 as I know it is good hopefully it's just the coil"FLTG4LIFE" @FINALLEVEL , "PBH"
ok I have no fuel pressure so there is a couple questions first is the fuel pump relay the one on the driver side front fender? and also will the pump out of an aspire work because I can get one from a buddys wrecked aspireJustin Craig Paola Kansas my 4 passions, demolition derby,Ford 2.3s, my festiva and my kids
How do you go from "no start" to no "fuel pressure?"
Did you find something else or did something else break.
Think the aspire pump should work, but you will have to swap the just the pump itself onto the pump/sender assembly of the festiva.'93 Blue 5spd 230K(down for clutch and overall maintanence)
well with out fuel pressure the car won't start I finally was able to do further testing to find out that I had spark so the next step was to check for fuel pressure and I found that the pump wasn't working ok so the aspire pump will work if I put it into the festiva sending unit is there a way to test the fuel pump relay?Justin Craig Paola Kansas my 4 passions, demolition derby,Ford 2.3s, my festiva and my kids
Just seems odd that the fuel pump would work intermittently.
Did you check your VAF connection, as there is a microswitch in it that permits the fuel pump to run.
Have you tried applying 12 volts direct to the pump to see if it truly has failed?'93 Blue 5spd 230K(down for clutch and overall maintanence)
I think the fuel relay is drivers side under the dash.
Also on the fire wall under the hood around the coil/wiper motor there is a relay bypass wire, hook up a jumper to the positive terminal on battery, this will make the pump run with a bad relay, pending the pump is good.
Best to look at a wire diagram. I don't remember exactly
which wire it is, when I need to do this I just trial and error. but my methods more risky
