How do you go from "no start" to no "fuel pressure?"
Did you find something else or did something else break.
Think the aspire pump should work, but you will have to swap the just the pump itself onto the pump/sender assembly of the festiva.
Random no start problem
ok I have no fuel pressure so there is a couple questions first is the fuel pump relay the one on the driver side front fender? and also will the pump out of an aspire work because I can get one from a buddys wrecked aspire
Originally posted by muddevil01 View PostTomorrow I'm gonna try the coil and disty out of my '91 as I know it is good hopefully it's just the coil
yes , yes, yes....expensive. It can be tested, it is expensive new. Ebay is your best bet for price if you want new. JY is best bet all together. Get the whole disty and just swap it out. Or if you know someone that has a disty see if they will let you use it to verify it is the problem.
Not exactly sure how to change it....never have. But if I had to I could.
Can I buy the module new or is it a jy part? also how do I change the module? Can it be tested?
Well my '93 started acting up today out of the blue it wouldn't start it would crank but not start so I checked for loose connections and all I get back in the car and it starts so I start driving it home and it quits just like someone shut the ignition off so again I open the hood and check things and it still doesn't start so after a bit of cranking I decide to push the car off of the road and wait for a ride well I get it coasting in gear with my foot on the clutch my foot slips and the car starts I drive it home and shut it off and it restarts and after about a dozen or so restarts I couldn't get it to duplicate the problem so I drive it to a friends house to see what he thought and when I get there and shut it off and it won't start we've tried everything we can think of and still no start any ideas? sorry for the long postTags: None
