On an 88 Festiva, if the gas cap vent is non-functional, can the vacuum created in the tank, stop fuel flow, to the engine mounted fuel pump?
My Festy stopped running Sunday. No gas being squirted into carb when cycling throttle. NEW fuel pump and it has 3/4 tank of gas. I removed gas cap and there was a huge vacuum on tank, which sucked in a lot of air when removing cap.
No fuel being pumped to carb from fuel line at carb. Fuel pump trying to suck my finger in the inlet side when cranking engine, so it is good.
I just checked/cleaned entire fuel system and it is clean tank to carb, including new filter. I was in the tank and it looks new inside. So...
should be getting gas. This car was running great and then this happened out of the blue.
Is the cap stopping it from getting fuel down the fuel line?
