I've done the actual conversion. However I am having a bit of a problem.
1st off I got it all mounted and it works.
But here is my question. I took the transmission out of a 93. My festiva is an 89. The entire swap was easy except one problem. On the transmission there is a wire that comes off the transmission. Its a single black wire. I am guessing this wire on the 93 was to make the transmission shift. My question is the 89 does not have this connector because they only came as a manual. Where do I connect this wire to make it shift using the sensor (I believe it is called the kickdown sensor)
I have unplugged the vaccume modulator on the trannie, and connected vaccume to it, It Will Shift this way but not as good as it did in the 93 using the sensor. I will only shift at 25, and 45 mph. So If I am doing 30-35mph or anything in between it will wind, and not shift until it reaches 4X RPMs
If anyone knows where to connect this wire, your help would be greatly appreciated
1989 ford festiva 1.3 Carb
PS: also car is running bad when she is cold any ideas?
