Replaceing pistons
  • Replaceing pistons
    I got an 89 ford festiva L with alot of miles that started smokein. Dont know anything about engines but after a compression test of 160 160 0 170 i took the head off and found a hole in the piston that you could stick a pencil in. Now im just wondering about how much money itll cost to fix and what steps to take in replacing pistons and rings. motor is still in the car and the cylinder walls look fine.
    any help is greatly appreciated. thanks
    Getting another block and swapping on the head might be easier, if your head is good. Another engine might be the easiest route.
    89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
    My site: 20tessa.sytes.net
      Another engine would be easiest and probably cheapest.. You are going to have to pull the motor any way so might is well just drop another fresh one in there...
      1989 Ford Mustang GT 5.slow
      1996 Ford F-150
        It is possible to do pistons and rings with the engine still in the car, but I would recommend pulling it and putting it on an engine stand (much easier to work with that way). You can buy or rent both engine cranes and stands from most of the big chain parts stores. For the steps to take, just pick up a Haynes manual, assuming your planning to do the work yourself it is probably the best investment you can make in your car. Only costs $25 and it will save you more than that the first time you do a repair yourself instead of taking to the shop. It will give you pretty detailed steps on removing pistons and replacing rings, including all the torque specs and other tips. As for how much the work will cost, depends on how much you want to replace while you have the engine apart. I would probably do the water pump and timing belt while its out (much easier) along with the oil pump (the metal that was part of the piston had to go somewhere, better safe than sorry) and of course you will need at least one piston, a set of rings, and a head gasket set. Welcome to the forum! Let us know how the ring job goes
        No festiva for me ATM...
          if you find that it is un rebuildable it'd be the perfect canidate for a swap...
          Andrew Walker
          Current Daily Driver:
          89 Nissan D21 SE V6 5 speed 4x4
          Projects in the works:
          84 Mercedes Benz 300D(T)(Baby) currently awaiting transmission transplant/ full on restoration
            Time for a B6 swap.
            91 Festiva BP Autocross/Track/Rallycross hopeful
            14 C7 Z51
              I rebuilt my engine in April. I got a complete rebuild kit from rock auto for about $330. With the help of a couple of buddies we had it done pretty quick. The thing that took the longest was waiting for the head to get done, and plus we were only able to do it on the weekends. The Haynes manual is a must, as well as take a lot of before pictures incase you forget where or how something goes back together.
              '89 Ford Festiva LX :fred:
              '12 Ford Focus
                Sorry but what was included in the rebuild kit?
                14 C7 Z51
                  not experience, and for that matter a hone, or even something to measure the bore before ordering the kit I'm guessing.
                  Since nobody else seemed to notice, he mentioned he had a hole in one of the pistons. Anybody care to guess what might have caused that. So what, were just going to write that off as termites? And now that he's got the thing opened up the termites are safely gone right. I'm thinking it's time for pictures of the head too, or what's left of these burned up valves, you know, because termites don't eat valves right?
                  Count me in as another vote for a B6 swap.
                    I think the B6 swap is a good idea too, if you can find one. Where are you located, by the way? Also, welcome!
                      Im sure i could find it on here but what cars and years would i be looking for to find a B6. What is a ball park price for one out of a junkyard. Im located in south west florida.
                        By the way, are you a manual trans? You'll want the ecm (b61k if you go with a b6) along with the engine, and I believe you can pull both off for the price of that rebuild kit that was quoted, unless it's shipped from far away. If you get it from someone here who's reputable, this will be a better deal than rebuilding that 1.3 anyway, cause what all these wananbe/nevahgonnabe engine rebuilders are failing to point out to you is: I believe you might even have had a little injector failure with it.
                          No one here claimed to be a "wananbe/nevahgonnabe engine rebuilder". Everyone was simply just giving a suggestion.
                          14 C7 Z51
                            Who cares about what made the engine blow up. Its a stock B3. This gives him the chance to swap in a b6 or b8 or bp. BTW I have built engines.
                              Really!? Ok you're right, nobody "claimed" to be, I guess I just took exception to the fact that so many people think that someone with no experience doing it, should be told to do it, as if it were an oil change. Having actually done it, I find that kind of advice more than a little irresponsible.
