brake booster removal
  • brake booster removal
    1993 festiva L How do you get at the 4 bolts supporting it?? I have a 1991 donor that has a good one and would like to swap.
    thanks
    93 festiva daily driver
    91 festiva parts is parts
    If it is the same as most they have studs in the booster that run thru the firewall and the nuts are on the inside up behind the brake pedal.
    Doug
    HD2500 Duramax Chevy
    Z28 LS1 power 500 +
