I have a 1990 L plus with automatic trans. About 8 out of 10 start-ups are fine. 2 out of 10 the starter will fail to engage the flywheel and grind against it. When this happens usually the next attempt will be a good start with no grind. Usually but not always. I am about to go take the starter out to visually inspect it. Any thoughts as to the cause of this? Anyone ever have a similar problem on a Festy?
I'm hoping it not from the starter being crashed when the car was running. I've not done this, but it happens and I know it not good. I've put maybe 1500 miles on since I got it. Could it be just the starter? I really dont want to pull the motor/trans for the flex plate.
I just got the car on the ramps and started repeatedly until I achieved a bad start. My theory is if its a bad spot on the ring gear it will be in view of the starter hole. Wish me luck.
