I have a really sloppy shifter, both left to right and up and down it moves. it makes a rattle noise when idle which is annoying. anyone on here have shifter bushings for sale or know a place to get them? If it moves up and down, would that mean i need a new housing for it too? Thanks
Shifter help
look in the articles section for the up and down fix. Shifter bushings are harder to come by but you can use ones found in the HELP section at the auto parts store. They are intended for van doors but there are some in the mix that actually fit nicely.Originally posted by djthebogan View PostI have a really sloppy shifter, both left to right and up and down it moves. it makes a rattle noise when idle which is annoying. anyone on here have shifter bushings for sale or know a place to get them? If it moves up and down, would that mean i need a new housing for it too? Thanks"FLTG4LIFE" @FINALLEVEL , "PBH"
if you dont mind spending a little money. www.corksport.com has bronzoil shifter bushings that will more than just fix the issue.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig
Where would those be listed on there? I have the same problem with my shifter and need new bushings. I also have a dual bend STS from a Civic I plan on installing soon. Do you know if the same bushings will work on that shifter?Originally posted by gauge_half_inch View Postif you dont mind spending a little money. www.corksport.com has bronzoil shifter bushings that will more than just fix the issue.Oh no!!! Hills, my only weakness!!!!!
easiest way to make sure it does not happen again......
stick an auto in it.....lol"FLTG4LIFE" @FINALLEVEL , "PBH"
Sooo does that mean you found a festiva? did you end up buying your friends?
Sorry don't mean to hijack but I think I remember an older thread.-------------------------------------------------------------------------------------------
My Musica! Click me!
Red Rocket 1988 L, 133,XXX miles, 4 sp. AC, hit guard rail in snow, RIP, saved everything but body
Black Rocket 1988 L 207,XXX miles, 4 sp. AC, engine, trans, wire harness, radiator from RR
Red Rocket 2 1988 L 138,XXX miles, 4 sp
White Rocket 1989 L 128,XXX miles, 4 sp. AC
