88 Festiva - Tons of issues
  • #46
    28- EGR vacuum solenoid
    29- EGR vacuum solenoid
    31- Air Control Valve solenoid
    34- Idle-up solenoid
    35- Idle-up solenoid
    38- EFE heater relay
    1993 Festiva L, aspire swapped, selling parts for a BP+T build.
    • #47
      can these solenoids and relay be fixed or a must to be replaced?
      • #48
        Have you replaced the plug wires with the correct ones yet?
        Also have you followed this advise yet?
        "The hoses have been removd from the EGR valve. That's the device to the back left below the air cleaner. The thing with the two holes on the right of the air cleaner is what Ford calls the pulse air system and as near as I can figure out it does the same as the EGR. If you don't have emissions testing in Jamaica you don't need them but as the fellow says the holes should be plugged."
        I'm guessing you are still getting most of those codes because you haven't corrected the vacuum line issues or plugged any holes and you probably still have the wrong plug wires on the car....
        • #49
          Originally posted by 91_festy_Gl View Post
          Standard NGK plugs work great and wires are your choice just make sure there for your specific engine. Looks like it had DOHC wires from a DOHC engine.
          So i should get some DOHC wires?
