I did say it was possible if the conditions were set just right. Guess I was a little off on what kind of temps a cigg produces though. I am not going to argue that point at all I know it can happen and I appreciate your concerns for my life. I take the risks and I know it can lead to possible dangerous situations. However let me let you know that whenever I pull off fuel lines hardly any gas comes out of the fuel lines at all. There is no spraying action at all and I may get 2 to 3 ounces at best total out of the fuel lines. More fuel comes out of the filter after I have it off than comes out of the actual fuel lines.
Again I know the risks and have actually lost a shop and multiple cars and thousands of dollars worth of tools due to a fire caused by fuel. The festiva in my Sig is one of them. It was however the fumes that were ignited and I was in no way shape or formed involved with anything that caused the fire. My friend was draining gas into a 5 gallon bucket which kicked up fumes and the hot water heater which was 3 ft behind the gas tank he was draining ignited the vapors. It was quite the experience and I thought I would never ever ever get over my fear of gasoline after that happened. I was there but again I had nothing to do with what caused the fire. One of the biggest things I learned from this was to do all fuel supply maintenance out doors away from un-realized ignition sources.
I am not arguing with you and I will keep everything you have shown me in mind. Some of the things I do are stupid I deffinately will not argue that. I am not however going to change my practices because I feel that I am very safe and try not to shower myself with gasoline lol. Thanks for the heads up, Jeremiah.
