bad alt
  • bad alt
    Ok this on a probe but same concept. The car has a system and has killed the alt because it was stock and they pull to much. And to day while on way home the alt quite and the bat didn't have enough to keep the coolant fan going and almost over heated. So i am wanting to find a alt that can put out a bit more than 80 amps lol.
    So any one have a idea of a alt that works off another car? That puts out more amps? This is the 2.0 motor so nothing special except the system pulls to much and need it to be drive able since my bp car is down.
    Don't know how much you're looking to drop on an alt., but according to a probe forum I am technically still a member of, you can use the V-6 alt. (2.5L) that puts out 90 amps. Or, you can go with this one.
    Still browsing the forum to see if any other ideas pop up.
    I will now with hold my usual Probe comments.:p
    Edit: If you use the 2.5L alt, you apparently have to swap pulleys, but otherwise it's plug and play.
    1988 L - 232K miles Batstiva
    1989 L - 247K miles Slick
      Thanks i thought you could, but didn't know if was enough amps to really make a difference.
        Hey Bat! Do you get probed often?
          Eh??
            Lets keep the comets down! I don't say dumb @$$ stuff in your threads.
              Comets, now they were good cars. Wish I still had mine.:p
              Seriously, you've got a 2.0 Probe, that would make it second gen, correct? What all are you running on the car? The alternator is about the only thing on my 97 SE that did not give me problems. Just extras for the sound system?
