I just did a MC(3 times now for nil) and "bench bled" it on the car every time before I hooked it up to the system. I assume when you connect lines and run them to the reservoir you should be able to just pump away and get all the air out?
This doesn't happen for me. Fluid goes up the tube as you push in the pedal and right back down when you let off it. The only way to stop this is to push in the pedal and then hold 2 fingers over the ends of the tubing before you let off the pedal. Otherwise you get nowhere. This is my 3rd MC. All had the same problem. This last one was taken off a scrap 88 and it works the best, but still not as it should. Am I missing something? With the current scrap MC, I can bleed the system for an eternity and you still get a pedal with absolutely no feedback and no braking till an inch off the floor.
