OK, I'm convinced my Festiva is possessed now. The TPS seems to be physically working as it should. The little arms aren't grounded together when they shouldn't or anything. BUT, when I tested things with my multimeter, some strange things happen.
Haynes(and another thread on here from a while ago) tells me the pins go reference, signal, ground from to bottom. So following the directions to back probe test things, I get nothing that I should. Testing the reference voltage gives me nothing. Testing the signal voltage gives me 12.47 volts. AND testing ground with the battery neg post shows no continuity.
Out of curiosity, I mess around a bit more to find that there is continuity between the "signal" pin and ground. I pop off the black rubber boot to find that indeed, there is a black wire in the middle. Now I'm lost. What in the world is going on?
The sequence(as best as I can tell) is reference, ground, signal, but signal of course is mighty goofed up at 12.47 volts.
