Rockauto tells me theres only 2 bearings required PER VEHICULE ,when theres actually 2 per side.
Are all 4 the same bearings? The part number is SKF BR11.
Rock Auto is wrong. Two bearings are required for each side. I am looking at the kit I got from FMS; two bearings, two seals, all for one side. Both bearings are identical, including the part #. The two seals are not identical to each other.
You can avoid reality, but you can't avoid the consequences of avoiding reality--Ayn Rand Disaster preparedness
Makes sense , I also found a timken set11 , which is a bearing kit for the front (both) , in the drivetrain/differantial category instead in the wheel bearings cat.
FWIW, same bearing set as the Aspire.
I'd go with the Timkins, few more dollars but fewer failures for me!
a bearing set means only one bearing and the outer race. you need two sets per wheel in the front.
no Tom, Arron has it right, a "set" consists of a bearing and race (2 required for each wheel: inner and outer) and the seal is nearly always an inner dust seal to keep grease in and dirt out (one per wheel).
If the brand of bearings changes do the preload spacers have to change too?
If the brand of bearings stays the same can the preload spacers be re-used?
I have a pair of spindles off a junk yard car. One of the bearings was replaced.
That side has a different size preload spacer than the other. One size up.
I think one is 12 and the other 13. Assume those are millimeters.
The preload spacers are hub specific not bearing specific.
So you could well have different spacers in the set of hubs.
DO NOT MIX THEM UP!
A good quality bearing/race is made to much higher tolerances than our hubs were.
Thus the need for 21 different spacers.
That said, if you got a crappy set of Chinese bearings you could well need to change the spacer.
I have stuck with Timkin bearings and have had no failures in those and have never replaced a spacer.
