rattle
  • rattle
    there is a rattling noise in the right rear while accelerating around 60 MPH, thought it was a loose shock/strut but it is tight. sounds like something is rattling between the inner and outer body. Goes away on deceleration. Any thoughts? i have a 93 GL
    Possibly loose baffles in the muffler??
      May be the heat shield above the muffler - attached to cargo area floor.
        thanks will give it a look
          Also verify that the hangers are holding the muffler in place properly. After a muffler job was done on Batstiva, one of the hangers was not fully engaged, allowing the muffler/tail pipe to travel just a bit, but enough to vibrate under certain conditions.
          1988 L - 232K miles Batstiva
          1989 L - 247K miles Slick
