Hi buddies!
I have engine oil mixed with coolant in the radiator(milky brown color). The pcv valve has little traces of water vapor.
I thought that my sister added oil to the coolant, but the oil residues were more and more.... So, I took the head off to check it.
The gasket has no signs of damage on oil/water holes. The machine shop checked the head and they said it was ok. I decided to port it.
I'm going to put everything together in a cople of weeks and let's see what happen.
I think that the throttle body gasket was leaking some water to the intake, but why so much oil in to the radiator?(Trans oil is clean)
Any similar experiences?
BTW I'm looking for the oil dipstick tube and hold down clamp le me know if you have one for me.
