Nox Failure this High...
Nox Failure this high is caused by the Catalytic Converter. High Nox is the result of High combustion chamber temperatures. Advance Ignition Timing will raise the Nox but you're is really high.
Magnaflow makes direct bolt in replacement Cats and at a good price. You may still need to adjust the Ignition timing to stock settings.
