Is their a difference between the left and right front lower control arms?
Lower control arms replacement.
Same length,bushing holes, just a mirror image of each other
Yep.
Before you start, spray PB Blaster up inside the hole leading to the captive nut that your LCA bolts go into. Do it a few days ahead of time. This should help prevent the dreaded "spinsalot" syndrome!
Moog is the way to go!'93 Blue 5spd 230K(down for clutch and overall maintanence)
Moog is the word I've heard.
Another thing you can do to extend the rubber boot's life is to spray it with Armor-All.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
+1000!!! American not china junkOriginally posted by Pu241 View PostMoog is the way to go!93 L B6T DD http://www.fordfestiva.com/forums/sh...ad.php?t=37751
RIP_90 LuX http://www.fordfestiva.com/forums/sh...ad.php?t=32249
RIP 88 LX / B8-MEhttp://www.fordfestiva.com/forums/sh...ad.php?t=26398
RJ
IIRC, the Moog's I've seen were "made in Korea."
Hmmm.
Unfortunetly, hardly anything is Made In America nowadays.Originally posted by Safety Guy View PostIIRC, the Moog's I've seen were "made in Korea."
Hmmm.
Karl
It is a very sad situation.
Dan
