I know this is a festiva forum, but it would also apply to anyone doing an aspire swap.
I recently went to change the tie rod ends out on our 1997 aspire. The old ones came off the knuckle with some, um, gentle persuasion, and a BFH.
now, when it comes time to re-assemble....
there is no damage to the knuckle what so ever. however, when i went to tighten the castle nut on the tie rod, the shaft spun. I think it was somewhere around 40 ft/lbs my haynes book told me to tighten it to. well, at 40 the shaft spins. Then after looking, i realized that the hole for the cotter pin wouldn't line up. not even close. So, in order to get the cottor pin in, the tapered end isnt seated properly in the knuckle. But, in order to get it seated correctly, it would need to be tightened more, which isnt happening.
sorry for the long post, but i hope it kinda explains my situation. The car feels alot better on the road, and the alignment is wayyy better than it was. But i still worry about that end. when you pull the wheel itself side to side, it has play.
I went with world suspension when i bought this. It measures the same as the original one, so idk, lol. either way, i wasnt going to shell out 62.99 for a tie rod end at my local napa, lol
