I just put my oil pan on. I then tightened the drain bolt and rotated the engine on the stand (the whole engine, not the crank). As I did so, I heard a metallic clack that sounded like it came from the oil pan!
Did I leave something on the bottom of the block or MBSP that is now causing this noise? I looked at my last picture, taken last night before I left the garage:
![](http://i400.photobucket.com/albums/pp81/SafetyGuyKarl/AquaMuttbuild165.jpg)
There is nothing I can see. I used the two end gaskets. Maybe something I left under the MBSP? I looked at an older pic and didn't see anything there either. I'm sure I tightened all MBSP bolts and the two oil pickup tube bolts. I torqued them all!
QUESTION: Is there something in the block that would make a noise when the engine is rotated on the stand about 180 degrees (turning from bottom to top)? In other words, could this be a "normal" noise? I turned the engine several times and it sounds like it could be a "regular" thing flopping around. Maybe something on the oil pump that reverberates into the pan?
In the meantime I'll see if I'm "missing" any small tools, sockets, etc.
Thanks, and.............................Arrrrggghhhhh!!!!
Karl
Karl
