I have an 88 LX with a carb. Recently the car started dropping power until it wouldn't get out of it's own way. Hills I use to climb in 5 now require me to downshift to 3rd or even second at some points. I noticed if I moved the distributor, that performance was better, but eventually it lost power again.
I replaced the timing belt thinking it may have stretched, but that didn't alleviate the problem either. I have verified the timing by lining up the timing marks, and have even tried advancing and retarding the camshaft by one tooth in either direction. I did this since I thought I could be off one tooth. It is now back to the stock location.
I have a done a tune-up with new, wires, cap, button and plugs. The old plugs looked terrible, but new plugs made no difference in the way the car runs.
Compression tests show about 130lbs across the board, which isn't too bad considering the mileage. 260k.
The car just seems to be in a constant bogged condition. I'm planning on a carb swap or rebuild soon.
Any other ideas?
Any other ideas?
