Well I just recently put a webber carb in my car. The only thing I had left to do was tune the carb. It has been about two weeks since I last touched her due to surgery. So today I figure I would brave the cold weather and tune her so I can quite spending my money on gas for the truck. However, the car wouldent start. Well it would start briefly. Then when she would die I could hear the carbs butterfly close. It got to the point where the battery couldent handle it anymore so I hook the truck up to it. She started up but would die shortly there after. Now all she does is crank and crank and crank. I am really close to getting rid of her, since I am putting more money into her than my truck. Any advice on how to fix her would be greatly appreciated. I already know I have to get a battery or charge mine. What I need to figure out is why she wont fire up anymore.
P.S.
The check engine light is on. i checked the codes and its for all the vaccum senors. I assumed this is due to me hooking the electric choke up to one of the power wires. I already disconnected the choke and tried to erase the codes. What did you guys hook your choke up to? I know it was hooked up to the alternator, but I was told it had to be hooked up to 12 a constant volt wire.
P.S.
