I dont know if its the heater core or not because its not leaking anything anywhere, if i set it on defrost warm air comes out but through the vents its cold air. Anyone have the same problem?
heater problem
Heat doesn't come out of the center vent on any setting.
This is just how it is set up.
You can get defrost and heat to your feet though, which if the heater core is not clogged will be more than sufficient.'93 Blue 5spd 230K(down for clutch and overall maintanence)
This. If you've got unclogged elements and feed pipes, cranking the heat through defrost will have you roasting in no time.Originally posted by Pu241 View PostHeat doesn't come out of the center vent on any setting.
You can get defrost and heat to your feet though, which if the heater core is not clogged will be more than sufficient.1988 Chevy Sprint Turbo 997cc
