Broken bolt?
  • Broken bolt?
    I see a lot of posts here about broken bolts (as will happen with old cars) and just wanted to throw out a good tip that may save somebody someday.
    Tip: Use a "left hand" drill bit. (not a joke!)
    Most drills are "right" hand, meaning they work by spinning clockwise
    They happen to make "left hand" drills. They work by spinning counter-clockwise.
    To tighten a bolt is clockwise (same as right hand drill)
    but to loosen it, it is counterclockwise (same as left hand drill) See where i'm going?
    By using a "left hand" drill, many times the bolt will just unscrew itself when the drill bit catches on the bolt! Bolt comes out in like 1 second.
    These are available at tool supply stores that sell cutting tools.
    Just FYI
    (Disclaimer: Does not work for a rusted in or a really banged up or stuck bolt)
    Dan
    ^^^Bumpity bump. not sure if anyone saw this. (posted late at night)
    Dan
      I use left hand bits all the time to remove broken bolts.
      93 GL modyfied!!!
      :fish:
        pb blaster and a torch work well too..... for those really stubborn broken bolts!
        88 festiva lx, 2.3 turbo rwd swap in progress
        1999.5 f-350 4x4 7.3 gtp38r 5" exhaust ect.
        R.i.p. 1990 Western Star 5964s 3406b 530whp (4.2mpg!)
        00' western star flat top ex, 600hp 6nz 2250tq, 18918b, 3.55, full lockers, 6" straight pipes
        03' gt, full termi swap 700+ whp build
        sponsered by,
        pam pam's junk, dayton OR.
        Bob's ok tires, salem OR.
        Clausen Truckin', keizer OR.
          easy-outs are also available..... they are like a reverse screw, you just predrill the hole with a regular drill, then use this to back out the broken bolt...
          -Aspire brake swap COMPLETE!
            the square style easy outs work much better than the screw style. i always seem to break the screw style lol
            sponsered by,
              I've been using both for years. Especially the PB Blaster and heat. Usually the reason the bolt broke in the first place is because it's rusted and/or corroded in place.
              My cousin swears by a couple of light taps on the broken bolt along with the heat and PB Blaster.
                I use to be skeptical of Pb blaster and heat and now I use it almost on everything, The few light taps definitely helps too.
                Also if the head gets stripped you can cut a slot in the head and then use a flat-head screwdriver to get it out.
                14 C7 Z51
                  The left handed bits won't do you much good if the bolt is stuck.
                  93 GL modyfied!!!
                  :fish:
                    Yep. See the "disclaimer" in 1st post.:p
                    Dan
                      Rusty bolts
                      Heck just use a left handed directional wrench. LOL
