Buzzing A/C control amplifier
  • Buzzing A/C control amplifier
    My control amplifier box has a mind of its own.
    It buzzes and randomly turns the A/C compressor and radiator fan on and off, even though the A/C button's not pushed in and the blower's off.
    Any thoughts on this? Do I have a stuck relay somewhere?
    Regards,
    Tim
    White '89L auto - Sold!
    Silver '06 Rav4, 95k!
    try a/c relay #2, the amplifier does not turn on your cooling fan,
      You're correct. I have a fan on the condenser though, which is being turned on with the compressor. I meant to type "condenser" but "radiator" came out instead.
      I'll check that tomorrow.
      Thanks!
      Tim
        is this the a/c you added on your main festy?
        is this a/c system off of a later model festy?
          It's the one on my main Festiva - the system I cobbled together from parts of a dozen different Festivas. It's been 6 months and it still blows cold!
          You hit the nail on the head - it was relay #2!!! It would clack on/off if I tapped it with my finger, and when I popped it open the spring was worn.
          I replaced the relay and everything's working well so far.
          Thanks!!!
          Tim
