Man, I think I got a little problem with my festy.
Oil is coming up through my valve cover breather.
I'll make it short. I checked my PCV valve and the vacuum line to it. Both working good, PCV doing its job, LOTS of vacuum on the line, but, here it is, it is still blowing oil out the valve cover breather.
Only thing that would cause that is pressurizing of the crankcase, which includes the upper area of motor up to the v.cover.
Let me give some backstory. It was leaking oil @ v.cover gasket. (original) So i changed the gasket, painted cover..etc....pretty much when this oil started appearing.
I THINK IT IS A HEAD GASKET.
See, when the old gasket was there, it appeared as just an oil leak, but now that I have the new gasket the v. cover is "sealed", thus the oil now blowing up the breather, as the pressure is greater than what the PCV can evacuate.
Well, thats my theory anyway.
No water in oil, no white coolant smoke @ tailpipe
Got anyother thoughts that may cause the oil blowing upward thru the V. cover breather?
Could a burnt valve blow upwards thru valve seal and pressurize it?
I'm wondering how long this has been like this. I think the new gasket made it show up.
Any ideas would be great.
Thanks, Dan
Thanks, Dan
