I've been searching all over for a FULL rebuild kit for a b6t and cannot find one. All I can find is a re-ring kit. I want bearings rings and pistions and all new gaskets. Anybody know of a reputable company who has a kit like this?
b6t rebuild kit
b6t rebuild kit
88 festiva lx, 2.3 turbo rwd swap in progress
1999.5 f-350 4x4 7.3 gtp38r 5" exhaust ect.
R.i.p. 1990 Western Star 5964s 3406b 530whp (4.2mpg!)
00' western star flat top ex, 600hp 6nz 2250tq, 18918b, 3.55, full lockers, 6" straight pipes
03' gt, full termi swap 700+ whp build
sponsered by,
pam pam's junk, dayton OR.
Bob's ok tires, salem OR.
Clausen Truckin', keizer OR.Tags: None
It said "under construction" site dosent work
sponsered by,
Ok its working now. Thanks guys. And I'm planning on running 14 lbs of boost should I stay with stock compression or bup the compression up and drop some boost pressure?
sponsered by,
wow its a dd so im gunna put the bov at 10 psi then move it to 14 to 16 ish for the track
sponsered by,
Get a rocketchip ecu for it too unless u r going to run ms. That will allow u to run 18lbs no problems. That's what mine does at the track and keep it around stock 9lbs for dd.1988 Ford Festiva "Sonic" BPT g25mr MS2 standalone ecu, FOTY '11, Best Beater FMV, Fan Favorite FMVI
1989 Ford Mustang GT 5.slow
1996 Ford F-150
I used a miata rebuild kit.Current cars:
I wasant sure if a miata kit would work bc I wasant sure if the rings where different? What year miata? Is it the mx5?
sponsered by,
Anything with a B6D, I think 1989-1993.Current cars:
sponsered by,
Ebay is a good place to fill in the gaps, but they have pretty much everything you're asking for in one capacity or another.Originally posted by 1988festivazoom View PostI've been searching all over for a FULL rebuild kit for a b6t and cannot find one. All I can find is a re-ring kit. I want bearings rings and pistions and all new gaskets. Anybody know of a reputable company who has a kit like this?
Yep... Importperformanceparts is good too.Originally posted by doylerl View Postrockauto.com
If you're set on replacing the pistons, bumping the compression is a good idea, but only if you're heart-set on running at least two of the following: upgraded intercooler, highest octane possible, and alcohol/water injection.Originally posted by 1988festivazoom View PostOk its working now. Thanks guys. And I'm planning on running 14 lbs of boost should I stay with stock compression or bup the compression up and drop some boost pressure?
If you're set on replacing the pistons, bumping the compression is a good idea, but only if you're heart-set on running at least two of the following: upgraded intercooler, highest octane possible, and alcohol/water injection.Originally posted by bhazard View PostCouple of the Capri guys run the 9.4:1 block on 16 psi all day long.
A blow-off valve... I think you mean a collaborative effort between the wastegate and the manual boost controller. You'll need a chip.Originally posted by 1988festivazoom View Postwow its a dd so im gunna put the bov at 10 psi then move it to 14 to 16 ish for the track
This.Originally posted by Flyin4stroke View PostGet a rocketchip ecu for it too unless u r going to run ms. That will allow u to run 18lbs no problems. That's what mine does at the track and keep it around stock 9lbs for dd.
*nods*Originally posted by chrisofna View PostI used a miata rebuild kit.
Yeah MX-5 Miata... ensure it says 1.6L and/or 1990-1993 and you should be golden.Originally posted by 1988festivazoom View PostI wasant sure if a miata kit would work bc I wasant sure if the rings where different? What year miata? Is it the mx5?1988 Chevy Sprint Turbo 997cc
