Hookay so here goes:
I took my car to get inspected and they said I had a leaking caliper piston. Being close to the holidays I decided to rebuild it instead of replacing it. All that went well but then when I went to bleed the calipers the bleeders broke off. I bled it by the lines and the pedal seemed super stiff like normal before the caliper started leaking.
Until...
I started the car and now it goes halfway down and does not get hard till I pump it and still isn't that stiff. I went around and re-bled the system back to front and it seemed to be better but now its back to having to pump it up to stop. The thing that gets me is that its rock hard till I start it, then its spongy.
I'm not leaking any fluid, or at least not a noticeable amount by the reservoir level.
I'm thinking replace the caliper? Might upgrade to EGT/Protege LX/MX3 GS/4WD Protege Calipers.
Until...
So I'm not sure about this but that's my guess. I've never cut a caliper in half or seen a cutaway diagram. Maybe it doesn't work that way. However, I do know that air will want to rise in a fluid, so the air should try to go "up" and if it does, you won't get it out by bleeding at the brake line. What I think happens is that your hydraulics are all fine until the pressure tries to build in the caliper top section. If there's air in there, then it compresses (gas is compressible while liquid brake fluid is not).
