Fusiable Links? awg vs amp question.
  • Fusiable Links? awg vs amp question.
    I know they need to be 35amps red and 15 amps brown, but all I can find are 14 and 18 awg fusiable link wire...no mention on amp rating does anyone know the amp rating as it relates to awg?
    Thanks
    Those who think drifting through life is easy, never tried it in an FWD.
    actually its 30 and 15 amps (originally 25 and 15 before the TSB). And you can use a cartridge fusible link (looks like a big plastic fuse). It plugs in place of the wire links.
    Jim DeAngelis
      Thanks, Ill go look for one.
        links
        i have some from a junkyard but do not know what color they are and they are from a festiva.
          Re: links
          watch out they might be rigged wire instead of fusible links
