OK, just put on the new 14" rims with 175/65/14 tires....
All I can say is... major rub a dub dubbing going on.
I have 102k on my stock festiva suspension. Maybe it is getting worn out? Maybe these rims / tires are just not a good combination?
Are the Aspire struts stiffer than a stock festiva? Does it raise the ride height at all?
If my suspension really is "shot" I'll replace it..... I don't want to get into a complete swap.
The back seems to be rubbing on outter fenders. If the car was 2" higher, this wouldn't be an issue.
Front seems to rub if I hit a big bump or turn into my driveway.
How might one go about RAISING the car 2"? It is either do that, or try to sell my brand new tires & used rims and just stick with the 12" rims / tires.
I've already put a lot of $$ into the rims / tires, and will most likely lose $$ if I try to craigslist em.
Suggestions? Maybe just stiffer springs front & back?
Thanks everyone!
~Phil
Thanks everyone!
~Phil
