Radiators for festiva
    Originally posted by 1988festivazoom View Post
    if they are pipe thread, get some brass caps from true value or fluid connector.
    And if you can't find those, just cut off a short piece of hose for each brass line and then plug up the hose with a bolt or something. That way you don't have to have a hose running from one to the other.
    Or use electrical tape to seal them, held in place with a ziptie.
    BTW, my B6rt Festiva has a single-core rad and a 180 degree theromostat, and never gets close to the center of the temp gauge, but is adequately warm even on the coldest days here (zero degrees).
      Let me get this straight: no coolant will leak out if I didn't seal them up? A simple "dust cap" made of electrical tape and zip ties, or a substitute will do?
      If so, then it won't be a problem. I may be able to find some rubber caps to use on the outlets. Cane tips, maybe.
      PS: I just realized that two separate tanks would explain the two drains!
