90 l plus below zero in winterset ia. Got front end covered temp. Just get's off the c. Maybe a hint or two to try. Thank you steve
Help heat me up
Know about the 2 stage tstat? I have the parts place single stage and used a 3/4" gate valve from Lowes plumbing section in the upper rad hose to set the temp where I want it. Works great for me with no grill blocking at all, but we aren't below 0, so you probably want to leave the block.Any difference that makes no difference is no difference.
Check to be sure you have the 2 stage thermostat, available only at auto dealers.
The T-stats from auto stores are Stant single stage and will not work properly
Back flush the heater core to clean it, too.Dan
Feel your pain, we have been in the 10 and 20s all month, poor little festiva engine doesnt genrate enough heat for me. I have the correct t stat and blocked grill, not much helps. Dress warm and pray for spring.Originally posted by steve mount View Post90 l plus below zero in winterset ia. Got front end covered temp. Just get's off the c. Maybe a hint or two to try. Thank you steveLast edited by NovaSS; 01-13-2011, 09:24 AM.money pit
No spitters were I work, you swallow it all. The Company feels if you already have it in your mouth why waste it.
I'm prayin', i'm prayin'....Originally posted by NovaSS View PostDress warm and pray for spring.
Dan
We're in the single digits and I have pretty decent heat..... Not enough to roast your balls but enough to keep your breath from foggin up the windows lol.
Do people with b6t and the BP use two stage stats? My heater doesn't have much heat and I replaced my thermostat because it was stuck open. My heat only gets Luke warm.Originally posted by bhazard View PostMy b6t will melt your face if you give it enough time.Last edited by Charlie1717; 01-13-2011, 03:25 PM.-------------------------------------------------------------------------------------------
My Musica! Click me!
Festiva. In the Winter it means...
Freeze
Every
Single
Time
I
Visit
Anywhere
If you're expecting to drive around in shorts in the Winter, you picked the wrong car.Festiva: Because even my dog can build a Honda.
both of my festivas use a regular fail safe thermo stat from autozone, and the heat works excellent in both of them. I see no point in paying 25+ dollars for a dual stage t-stat when a regular one works just fine for me. One is all stock with a b3 and the other is bp swapped.Last edited by BP-Festiva; 01-13-2011, 06:01 PM.
Mine just must be a different issue thenOriginally posted by BP-Festiva View Postboth of my festivas use a regular fail safe thermo stat from autozone, and the heat works excellent in both of them. I see no point in paying 25+ dollars for a dual stage t-stat when a regular one works just fine for me. One is all stock with a b3 and the other is bp swapped.-------------------------------------------------------------------------------------------
Cold in Iowa
I feel your pain Steve, we live in Pella. I use the Two stage T stats and have warm heat, not so with the single stage T stats, our Bumper to Bumper parts store sells them. Check your local part stores you might get lucky.Originally posted by steve mount View Post90 l plus below zero in winterset ia. Got front end covered temp. Just get's off the c. Maybe a hint or two to try. Thank you steveAn idea can turn to dust or magic, depending on the talent that rubs against it.
