I bought my third running Festiva the other day.
I just finished putting in a clutch and replaced the transmission in one of my other Festivas so I now know a little bit about the noises, snapping, crackling, and popping that bad trannys and bad joints can make.
This new Festiva addition of mine, the clutch doesn't slip at all and all gears seem to shift fine but when ever there's torque applied (step on the gas initially), there's snapping and popping noises.
My first guess is that it needs new half-axles. Could be a tranny problem but I refuse to think about that right now.
You know how everyone says to just turn the wheel all the way one way and if there's snapping/popping noises then it's the joints. But, bad half-axles can make bad noises even when their going straight, right?
