OK to start its a 1989 carbed, 4speed festiva.
The brakes went out on me thursday (mostly)
Brake pedal is soft then about 1in from bottom it locks up the front left & back right.
There are no leaks anywhere.
Replaced the master cylinder yesterday.
Attemped to bleed the brakes but there was no pressure to move any fluid.
Every once & a while I would get pressure.
So now im thinking its the proportioning valve.
Btw I still have the same 2 wheels that can brake if I floor it.
I'm kinda at a loss.
Ideas?????
Ideas?????
Poverty produces creativity
