I have an 88L carby and when you maintain a cruising speed of 55, 60, or 65 the check engine light will come on after about a 1/2 hour or so and more frequently after it pops on for the first time. If you burb it, or just take your foot off the gas for a second and re-apply it will go out immediately. Any ideas on what it may be? There are no codes to tell me a thing. ECU possibly going south?
Check Engine light question
Does it run any different when on??
Sounds like an egr issue to me, possibly just carbon build up in the egr passages or possibly a split vac hose in the egr system.Hotrod Forums Directory * D&D Discbrakes 61-67 Econoline Conversions
I dont believe carbed festy have ECU's. I would check vaccum ^^like they econo said.Originally posted by kartracer46 View PostI have an 88L carby and when you maintain a cruising speed of 55, 60, or 65 the check engine light will come on after about a 1/2 hour or so and more frequently after it pops on for the first time. If you burb it, or just take your foot off the gas for a second and re-apply it will go out immediately. Any ideas on what it may be? There are no codes to tell me a thing. ECU possibly going south?
my festy did this too when i had the orginal 1.3 i just took the bulb out.. easy fix! lol
88 festiva lx, 2.3 turbo rwd swap in progress
1999.5 f-350 4x4 7.3 gtp38r 5" exhaust ect.
R.i.p. 1990 Western Star 5964s 3406b 530whp (4.2mpg!)
00' western star flat top ex, 600hp 6nz 2250tq, 18918b, 3.55, full lockers, 6" straight pipes
03' gt, full termi swap 700+ whp build
sponsered by,
pam pam's junk, dayton OR.
Bob's ok tires, salem OR.
Clausen Truckin', keizer OR.
No, it doesn't act any different. But I have never pulled the EGR valve, so I can start there. The vacuum lines are new about a year ago, but I will have a look at them.Originally posted by econoaddict View PostDoes it run any different when on??
Sounds like an egr issue to me, possibly just carbon build up in the egr passages or possibly a split vac hose in the egr system.91 Festiva GL "Scrat"
82 Honda Goldwing GL1100i
85 BMW 535is "Brunhild"
So when your brake light comes on you'll do the same thing?Originally posted by 1988festivazoom View Postmy festy did this too when i had the orginal 1.3 i just took the bulb out.. easy fix! lol'93 Blue 5spd 230K(down for clutch and overall maintanence)
Sure, if you can't see the problem, it doesn't exist.Originally posted by Pu241 View PostSo when your brake light comes on you'll do the same thing?
1989 L - 247K miles Slick
When my oil light came on, I just removed the bulb.Festiva: Because even my dog can build a Honda.
Oh say it isn't so JPT!Originally posted by JPT View PostWhen my oil light came on, I just removed the bulb.
I got respect for you.
You know it was likely a failing pressure sensor on the back of the engine below the intake manifold, and I think, to the left of the oil filter.
Fairly easy to replace, maybe more difficult to find the correct part.
Tell me you at least checked the oil pressure to make sure it was OK before pulling the bulb.
Hey, going to be up your way Thursday and Friday, or at least closer than I'm now. Have and interview in Kingston, RI Friday.
But flying into Providence, RI on Thursday.
Drop me a PM and see if we can't meet somewhere.'93 Blue 5spd 230K(down for clutch and overall maintanence)
LOL! You KNOW I was kidding, right?Originally posted by Pu241 View PostOh say it isn't so JPT!
I'd love to meet you, but I'm not sure I can. Work has me very busy now. The holidays are over and thousands of older cars are now coming out of the rental fleet.
Good time to buy a used car. Especially before all the dealerships buy them up for the President's Day car sales.Last edited by JPT; 01-18-2011, 09:24 AM.Festiva: Because even my dog can build a Honda.
mine did this until i unplugged a vacuum line
never comes on now
unfortunately i don't have a digital camera to take a picture of which line i unplugged...
it has something to do with emissions if i am not mistaken... arty had me rehook it up at the 4thstiva event and the light started coming back on again and i ended up unhooking it and plugging that line again
i have no idea what it is called because well i'm stupid like that...
I have killed a bulb on a warning system one time. My wife had an 87 escort when I met her. The low coolant light was ALWAYS on. She had it to the shop many times to have it checked. Coolant was never low, the shop couldn't figure out why the light stayed on. So, I pulled the bulb. Problem solved. Eventually, Ford had a recall on the sensor, which was faulty and caused the warning light to be on all the time.
Cleaning the EGR valve is pretty simple. Just be carefull not to let any dirt or carbon fall into the engine at the port when the valve is removed.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
