I have a 1992 Festiva and the driver's side front automatic shoulder seatbelt is stuck in the forward position. I kept grabbing the belt inadvertently as it was so close to the steering wheel so I just unhooked it. Now I'm driving around with no shoulder belt and a lap belt that won't retract.
The passenger side works so it's not the fuse. How do you access the mechanism? Is it just stuck or is there some wiring/motor issue?
I have another 1993 Festiva that the passenger side front automatic seatbelt is stuck in the back position so at least you can manually hook and unhook it. However the buzzer goes off intermittently for no reason.
So, how do you fix these stuck automatic seatbelt issues?
Thanks.
Thanks.
