I recently changed the cv joints on my 1999 5spd aspire. The differential seals looked a little old so I changed them. The right side was leaking so I pulled it all back apart again. There are no burrs on the sealing surface of the cv joint and the seal has no visable cuts or tears. The spring was still properly installed in the lip portion of the seal. I installed a new seal and put rtv on the outer rim to make extra sure it was sealing in the bore. The shaft is definitely installed all the way in. Still leaking.
When I had the shaft out, I tugged on the inner race of the output bearing in the tranny and it had no play. With the shaft reinstalled, I can grab the inner cv joint and shake it back and forth about a millimeter which is slightly more than the side that isn't leaking.
My first theory is that the remanufactured cv shaft has been machined out of tolerance (shaft too small where the lip seal contacts it or where it goes through the inner race of the tranny output bearing). Anyone know the dimensions and tolerances for the right side inner cv shaft? Then I could pull the shaft, measure and return to Autozone if it's out of spec.
The remaned right side cv axle didn't come with the rubber mass damper about halfway down the shaft like the stock one did. My second theory is that there is some kind of vibration causing the seal to leak because of the absence of this damper. Anyone else have trouble running without the damper?
Any other ideas? Thanks for the help.
