Just bought a 94 festy....... has a nasty oil leak from somewhere. Engine is coated, seems to have most oil on the front of the engine and the belt side of engine, and of course, the bottom pan. The alt belt is picking it up and flinging it onto the inside of the hood. Going to pressure wash today.
Wondering, do festies have a *common* problem area that leaks oil?
I`m thinking valve cover gasket, oil pan gasket, front crank seal.....hope not that one, or the dist. O ring to address first. Have I missed any likely spots?
Also, the alt is coated in oil. Last owner says there was a charging issue with it, but on the drive home, no dash warning light indicating a charging problem came on. Still, I`d like to clean the oil from the alt. Any suggestions? Degreaser? Brake cleaner? Can it be power washed?
Thanks.
Thanks.
