What are the odds that I ended up with 2 bad batteries in a row?
Slick has been having some issues. Started back in late summer/early fall. If he sat for more than two days, no start. Jumped him, verified that the alt. was doing its job. 14.75 VDC at idle, with nothing on. 14.35 VDC at idle, with everything on. Okay, alts working. Shut the car off. Verify I have no draw on any fuses under the dash. Leave the car alone for two days, won't start. Battery voltage less than 4 VDC. Jump him again, verify the alt is working, and voltage across the battery is well within spec. Shut the car off, verify good voltage at shutoff. Disconnect the battery from the car, leave it alone for 2 days. Check voltage- battery sits at 3.9 VDC. Take the battery back to AZ, have them test it. Result- battery is crap. Take delivery of new battery, bring it home, slap it into Slick. 2 days later, battery is dead. Re-verify that charging system is working, and battery is above 12 VDC after shutoff. Disconnect the battery from the car, leave it alone for 2 days, check it, and voltage reading is 2.91 VDC. The voltage starts dropping within minutes of shutoff, and is below 12 VDC within 30 minutes. Still have no draw on the fuses when the car is off.
So, I'll be packing up my less than 1 month old battery, and heading back to AZ. At least at this point each new battery is free, but damn.
