Any tips on changing the speedometer cable? Anyone done it?
speedometer
I don't think its ever been done!
Advanced Search
Keywords: Speedo cable
display Posts (not threads)
Read the posts, all the details you need are there.
I'm also sure other search parameters will net you what you need.
Other may even find a specific post for you or spoon feed the instructions.Last edited by Pu241; 02-06-2011, 07:07 AM.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Originally posted by Pu241 View PostI don't think its ever been done!
Advanced Search
I will give you a little more info. Remove it from the Tranny first. Then you will have slack to remove your cluster. If you need more info I'm sure there is a thread on it-------------------------------------------------------------------------------------------
My Musica! Click me!
