n/a 323 cluster
  • n/a 323 cluster
    I was needing help wiring an 94 323 cluster i have seen the wiring diagram for the tack cluster from the gt but didn't want the tack cuz i have one on my dash so i got a non tack cluster from the j/y and didn't know if the wires are the same and wonted to know be four I tour in to the festy.
    will with both the cluster and the wiring diagram in front of me i found out the the 323 and the 323 gt wires are the same but are in a diferent spot but the corresponding leters are the same so if this works ill post some pics a
      If you were looking at the diagram for the GT, then chances are the GT diagram was for a 88-89, if you are working on a 94' then its a different chassis and won't be the diagram you'd want to follow
        yah kinda figered it was to good to be true but some are the same i got a small bat and iam hooking them up it see what will light up and so far the turn singles are the same the temp gage the break light ,oil light,check engine light, and fuel tank gage but right now it looks like their will be a lot of unused wires but ill keep workin on it lol
