Does anyone know how to troubleshoot and fix the speedo? The other gauges work and when you drive it I can hear something that sounds like a cable turning. This is a 1993 Festiva.
Also, the dashboard lights do not work. The domelight doesn't work either and I hope I can track that one down.
Finally, my emergency brake doesn't engage. I pulled the cover and checked that the cable is still hooked up on the top side so I am guessing maybe it's a problem at the back brake?
Thanks in advance for any help!
If not then tighten it.
