Some of you midwesterners might remember Mark Mich, with the Mini Mouse Festy truck and trailer. Anyways, he has a 90s Festy with auto that the passenger side halfshaft will not come out. He has even drilled a hole through the shaft by the transaxle, put a bolt through it and tried a porta-power to get it out. Nothing. Took the other halfshaft out, put a bar through to the back side of shaft and tried hammering it out. Nothing. Any help would be appreciated that I can pass on before he does a complete tranny swap to solve a halfshaft swap. Thanks!
Help with halfshaft
Help with halfshaft
ENFORCER - Midwest Festiva Inc., Iowa
#2 .....Cheesehead
#3 '91 White - Donor Car
#4 .....Montana Project
SOLD----Levistiva for $1500
Bought her back for $450
Now that's darn near priceless!!Tags: None
Unfortunatly there's not much advice that can be given, I've had an axle that didn't want to come out and I ended up scrapping the tranny
Best advice would be rotate the axle, try popping it out, if it still won't come out, rotate it again, try again etc,Last edited by Damkid; 02-08-2011, 05:30 PM.
Like Damkid said, keep rotating it, but push it back in each time. Try using (or making) a heavy slide hammer puller that you can attach to the hub next to the transmission. I've found that a hard shock works better than applying increased pressure like with a porta power.You gonna race that thing?
I had the same problem when trying to swap over a tranny to another festiva and never did get one axle out. I ended disconnecting the axle at the cv joint the pulling the engine and tranny out then used a cold chisel and a mini sledge to finally get one side out. The other side never did come out.
Just disconnect it at the joint and and put on the new one.
I had this problem with a Toyota i cut the boot in the cv shaft closest to the motor and slid the shaft out so only the end was in the trany ( i did that so i could get a straight shot on it for pulling) and used a slide hammer with a 3 finger thing on the end took some time but it worked. I hope you get yours out !
2 pry bars, placed like wedges on opposite sides of the axle, and a few whacks to each one with a 5 lb sledgehammer did mine.Festiva: Because even my dog can build a Honda.
Rotational wiggling (does that make any sense?), might just collapse the spring clip on the end to close up on the tapers and allow the shaft to slide out, all the while using steady pry bar leverage.
I like all this, everyone has ideas, but long and short, you have to keep working on it till the thing comes out, .... use new or unmashed spring clips going back in.
Good luck!
I had a tough one and just kept getting bigger hammers, it came out , luckily only small case damage used Permatex Cold Weld.Aspires and Sways all around, Miata B6 installed, KYB G2Rs just installed in front. Wish for coil overs someday.
Can anyone say what inside the transmission is holding onto the axle? I'm planning to replace the axles when the weather warms up and would like to know what I'm up against.
BTW a control arm dropped off during a slow turn in 2009 and pulled the axle out of the transmission. There's a possible solution for a stubborn axle, use the wheel.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
A circlipOriginally posted by WmWatt View PostCan anyone say what inside the transmission is holding onto the axle? I'm planning to replace the axles when the weather warms up and would like to know what I'm up against.
A circlip -- ok. But what it the circlip butting up against? Does anybody have any photos from a disassembled gearbox?
I have a car I was disassembling for parts up in AK, but couldn't get the passenger axle out. So I pulled everything out in one unit, separated the gearbox from the engine, put the axle (with gearbox hanging from the other end) in the vise, and started beating the crap out of it, figuring I was going to sacrifice the gearbox anyway. STILL couldn't get it to come apart. I then opened up the gearbox to see what I could see, but couldn't immediately figure out how to remove enough parts to see the circlip and its environment.
I would just be nice to have a real photo of the enemy, not just a mental image of what he might look like!88L black, dailydriver
88LX silver a/c, dailydriver
4 88/89 disassembled
91L green
91GL aqua pwrsteer
92GL red a/c reardmg
1952 Cessna170B floatplane
