tried searching for a solution...but i found nothing...my problem is my wipers quit working completely they were just working and the fuses are good...do you know if there is a relay i should look at?? any answers would be awesome
wipers stopped
check the motor ground and make sure the motor isn't locked up mechanicaly.Trees aren't kind to me...
Also, don't know what the weather is like up yonder, but make sure you don't have a bunch of ice blocking the mechanism under the cowl. Since they were working, and just stopped, I doubt this is the case, but you never know. Does the wiper fluid still spray? Or is the whole switch dead?
1989 L - 247K miles Slick
